Pretty much what it says. Looking for some preload adjusters for my OEM forks on my 954. I know they are fairly cheap, but once in a while they go up here. Figured I would give it a try before I buy them new. If you have some, PM me. Thanks guys.
ConqSoft said:
Do you really plan to change your preload that often?
Hopefully not. Just making some final adjustments and figured they would be easier to use then the 22mm wrench. Although I'm pretty sure that whatever adjustment I make from here on out wont be much anyway. I think I'm pretty close to where I need to be. My neighbor has a 929 and I figured he could use them when I'm done. He just had a local guy do some majic on his front forks. Probably put it back together tomorrow.
Hey Conq. you can delete this WTB ad to keep things cleaned up a bit if you want. I have them coming from another member. Thanks.
