I have a 93 CBR900RR and I put an 07 CBR1000RR fairing front and rear on it. I made an adapter to fit the 07 subframe to my frame so the rear fairing bolted right up. Then I made some brackets that bolt to the 93 mounts and the 07 fairing. I put an 07 radiator and fan in with a couple small modifications. It’s a race fairing so I cut holes for the headlights and mounted a brake light and made it street legal. I also had the machine shop make some bushings and shims and adapters so I could put 04 Suzuki GSX-R750 17” wheels on it. New brake rotors weren’t to hard to shim and line up with my calipers either. A couple small brackets helped line up the front fender to my Lindemann Engineering tuned forks as well. Where there’s a will, there’s a way. Owning a welder helped to. It’s been 5 years and it’s all tight and going strong! I even have a rear seat now although not in the pictures. I didn’t pick the fairing because it would fit, I just liked the way the 07 looked and made it fit!
  1. Hell I have a 98 CBR 900rr and I have 05 housong frontend,09 Yamaha yzf R6 side fairings,& belly, & the actual 900rr rear end on mine! (Only mocked up for now) BUT made ALL of My brackets so it's solid! what til I get done!
