1 - 13 of 13 Posts
04 CBR1000RR 12,500 miles, valves were just checked and all were in specs, fresh synthetic 10w40 oil and Honda Filter, this is a video of me riding a loop in a sub here, you can hear the tick, is this truly normal??? Everyone says yes, any thoughts would be great. I';ve even changed exhaust gaskets thinking that might be it, no change, It runs great and no power loss what so ever, has done this since I bought the bike with 9,000 miles, I know the guy I bought it from and it was babied.
YouTube - Loop 1 reverse "cbr Tick"
normal...unfortunately...mine hasn't started doin it yet, but it only has like 6000 on it, so we'll see
the same kind of ticking sound came up on my buddies TL1000S right before the oil pump whent out and spun a crank bearing...
If that was gonna happen I'm sure it would have done it awhile ago, I have put over 3,000 miles with the same noise.
Wow 1krr's tick that bad. Wow I thought my 929 ticked when it was cold, but that was quite obvious even with the road noise distortion . I was thinking it sounded like the timing chain tensioner. Because you can hear it most when you accelerate and also when you let off the throttle.:idunno:
My 02 954 had a tick similar to that just not as bad, turns out my valves were a couple thousands out and the cam chain was streched replaced and adjusted, Now no tick. I would check the cam chain tensioner or even the chain it self.
Sorry, I didn't read closely enough. I was going to suggest exhaust gaskets too, but luckily I read your first post again. Could there be a leak somewhere else in the exhaust system, at one of the joints, or a hole somewhere?
I do have a header for an 07 CBR1000RR I think its the same as the 04, I will eventually get around to changing it just to rule that out as well. But for now I can't hear it at all with the ipod turned up!
It doesn't sound like exhaust. The sound of the exhaust drowns out the tick. I would get the head and cct triple checked. I wonder though if it might not be a minor piston slap. If the heads come back clean as a whistle, might be time to look at piston pins, and rod bearings.
Can't really tell under power, (exhaust noise) but low/no load really makes me wonder about piston pins. :idunno:
I don't like the sound of that thing. I can tell you that my 929 ticks but doesn't sound at all like that.
I have 35k on mine
1 - 13 of 13 Posts
