929 battery issues - Honda Motorcycles - FireBlades.org
post #1 of 24 Old 09-14-2012, 10:25 AM Thread Starter
Reputation Power: 9
929 battery issues
Hey everyone, my 929 gave me some trouble today, i turned the ignition on and the fuel pump primed and everything was great, i then came to start the engine and i heard a slight tick and then there was no more power, speedo and everything went off. I tried swapping batteries with my uncle's bike and fuel pump primed again, when i pushed the button to start the engine, that tick came again and all power went off. It seems like something is shorting the battery but i can't figure out what. I then jumped it from the car and it ran great but as soon as i took the cables off the bike died. After two fried batteries i don't get whats wrong...
"Money can't buy happiness, but it can buy a bike, and that's pretty damn close"
rdeuvletian is offline
post #2 of 24 Old 09-14-2012, 10:44 AM
Reputation Power: 113
Re: 929 battery issues
Was his battery KNOWN to be good? Not just assumed it would be ok?
Sky91 is offline
post #3 of 24 Old 09-14-2012, 10:47 AM Thread Starter
Reputation Power: 9
His battery was fine the dash lighted up and fuel pump primed, after i pressed the button to start the engine it turned over but before the engine could fire, that tick happened and all power went off, no horn, dash, lights or anything. I feel something is shorting out
post #4 of 24 Old 09-14-2012, 10:50 AM Thread Starter
Reputation Power: 9
It basically killed two batteries, i connected the battery's 2 terminals with a wire and it didn't even make a spark!
post #5 of 24 Old 09-14-2012, 10:56 AM
Just because the lights come on doesn't mean the battery has enough to juice to crank the starter motor. What voltages do they show across the terminals?
Sky91 is offline
post #6 of 24 Old 09-14-2012, 10:59 AM Thread Starter
Reputation Power: 9
That's the thing, the lights don't come on, it cranked then did this tick sound and EVERYTHING went off. Happened 2 both batteries. The battery is basically dead, i connected a piece if wire to both terminals and it didn't even spark once.
post #7 of 24 Old 09-14-2012, 11:14 AM
Reputation Power: 28
Did you check the voltage in both batteries?
In a dead/dying battery it will light up dash, signals, headlights but may not have enough juice to start on the button.
The fact that you are able to jump her from the car but not the batteries sounds like the issue is with the batteries.
I would check voltage and charge if u have a charger to rule out the batteries or find the culprit before worrying about the stator, RR or electrical issue.
Surteez is offline
post #8 of 24 Old 09-14-2012, 11:18 AM Thread Starter
Reputation Power: 9
No i didn't check the voltange. The thing is it lights perfectly and primes the pump but as soon as the button to run the engine is pushed, eveything will go off. I don't get what it can be. But i'm guessing since the battery doesn't spark when i short it with a wire then the voltage is extremely low. And if i jump it from the car, it will keep running as long as it is connected, once i take one of the wires off, it shuts off immediatly.
post #9 of 24 Old 09-14-2012, 11:22 AM
Have you ever had the start button off before. The 'short' could be with the button?
Surteez is offline
post #10 of 24 Old 09-14-2012, 11:24 AM Thread Starter
Reputation Power: 9
I always keep the cut off switch on run and just turn off the engine with the ignition. The Button that is causing the problems is the crank button.
post #11 of 24 Old 09-14-2012, 11:34 AM
Yes that's what I mean. The start button not the kill switch. Have u taken that off and looked at the wiring in there?
Surteez is offline
post #12 of 24 Old 09-14-2012, 11:39 AM Thread Starter
Reputation Power: 9
No i haven't, but it worked fine when i used it while jumping the battery from the car.
post #13 of 24 Old 09-14-2012, 11:42 AM Thread Starter
Reputation Power: 9
If there was anything wrong with the wiring or something shorting out wouldn't it have shown when i was jumping the battery from the car?
post #14 of 24 Old 09-14-2012, 11:57 AM
Which makes me think it's the battery
Surteez is offline
post #15 of 24 Old 09-14-2012, 11:57 AM
Somehow I don't think that'll be accepted as the answer though.
Sky91 is offline
Battery issues.. i think? greyg00se19 Honda CBR 600 6 10-04-2008 7:21 PM
battery recharging issues cosmo_sydney General Discussion 4 09-30-2008 12:01 PM
battery issues help 03degrassi Honda CBR 600 2 07-27-2008 9:23 PM
battery issues please help 03degrassi General Discussion 1 07-27-2008 7:55 PM
Battery Issues sgracida Honda FireBlade 12 09-17-2007 2:28 PM
