Changing spark plugs on the 929
19K views 20 replies 13 participants last post by  KIDRR
#1 ·
I got some new spark plugs for my bike. What do I need to take off in order to get to the plugs? Can some one give me step by step instructions on how to do the whole job or a link on how to?
Thanks in advance for any help
#21 ·
Well I guess everyone has their own favorite way but taking the tank off and the airbox and all the little plastic pieces is a pain in the a$$ It was'nt hard at all to just slide the radiator foward and jam my hand and the plug wrench in there.
#18 ·
Thanks a bunch Red Rider and Super Dave!
My buddy came over today and helped me do it..was'nt that bad once you see how....I just did it buy pushing the radiator foward and it's really tight in there.
#14 ·
Well my bike is in pieces in the back yard. I took off all the fairings and the tank and air filter. I just kept seeing more and more plastic under the tank. I guess i'll get a shop manual tommorow and see if that helps me at all.
At least I got the radiator flushed out and ready for the track.....and the rims off so I can get new tires on tommorow.
#13 ·
I just did mine 2 weeks ago, and I know alot of people love to remove the tank and crap, but that is a huge huge hassle and mess.
This is how Honda tells you to do it.
Remove your lowers, and undo the 2 bolts that hold on the radiator, there is enough hose to let the radiator swing forward and out of the way.
Use the factory wrench!!!!
It took me about 1 1/2 hours, but I think it can be done much faster, I think I can cut that to an 1 flat now.
Most of all, have fun.
#8 ·
I like the radiator method better, but that is partly because I can get my track fairing off and on in just a few minutes. The stock body work takes more time, because it has those side pieces to deal with.
Getting the plug coils off the very first time is hard. I had to pry them off using a piece of wood to protect the valve cover and a pair of channellocks. After they've been off once, and if they've been treated with dielectric grease, then they are easy to get off.
You will need to use the toolkit plug socket, because nothing else will fit down into the plug well.
#7 ·
Be sure to use a bit of anti-sieze on the threads.
The service manual says to move the radiator and replace them from the front, but a lot of people remove the tank and air box. It's really a matter of personal preference.
I think there has been some step by step procedures written up on this site, but you really should have a service manual if you're going to attempt this job IMHO.
#6 ·
I just changed mine and didn't remove the tank or airbox. I just removed the left mid cowl and removed the radiator bolts (there are two) then slid the radiator forward. You'll want to us a ratchet with the tool because a wrench only allows about 1/4 turn at a time.
