41 - 60 of 62 Posts
Re: wiring diagrams 98-99 900rr
hey i have a question for you. someone stole my 900rr a couple of weeks ago and when they had it they tried to hot wire it. so all my wires to the ignition is cut and they ran theyre own wiring to start the bike. so i dont kno what is suspose to be there and what isnt. where can i find a wiring diagram just for that? and is it really that hard to do like i need a shop, or can i do it myself?
Hi Killer. No u don't need to be a genius to do the wiring of your bike. If u follow the diagram closely u can do it yourself. It tells u exactly which wires go were. I've taken my whole harness apart, took out the wiring of my old original clock and replaced some wires with no hastles. Good luck
hey bro sent them to your email hope it helps. let me know if you got them if not can send agin.
Help I need 97 fb 900rr wiring diagram first was firing on 2 cylinders I replaced every thing pulse and ING coils stator used ecu new stator was no good I put back old one it works but now no fire from coils I ohm checked wires to coils first low voltage replaced bad wires to and from coils and ecu now have 12v at each still no fire to plugs bypassed plugs used screw driver and held on to it no spark I'm me hand help!!!!! Or just send me and email mikemoses1978@gmail.com thanks
I
Im having the same problem
41 - 60 of 62 Posts
