08 CBR1000, engine sounds like tractor at idle ?
17K views 19 replies 15 participants last post by  08silvercbr
#1 ·
Hi, new to this forum. Have a 2008 CBR1000 in Red/ Silver. Came from a couple of BMW's and 2007 GSXR 750. Anyway, was at a honda dealer today to pick up some oil and ask some questions? When I was there the service manager listened to my bike and told me to go to the dealer that I bought the bike from because of my bikes loud idle noise. It sounds like a combination of tractor and deisel engine. Mine has sounded like this since new. It now has 3000 miles and runs on mineral oil. Do all the 2008 CBR1000 have loud engine idle or is it just mine? Love the bike, not to crazy about the engine idle noise. I'm asking as I am trying to figure out if the service manager was just just trying to get rid on me as I was asking questions and he was not getting paid to answer or was he on the up and up. It all seems strange as he was the dealer that did my first service at 800 miles and the bike sounded the same back then. Any input would be appreciated. :confused:
#8 ·
I've been wondering the same thing about how loud the motor is. Mine is loud even when I'm running through the gears, very noisey, sounds like hell is going to break loose. (I hope I'm not the only one hearing this.) As long as I can put tens of thousands of miles on it, and keep it for a while without it breaking down, the motor can sound like an old John Deere or International.
#10 ·
Only after it is completely run-in. An engine will NOT run-in if you use synthetic oil. Best to use a top quality 100% mineral oil when running-in. Don't forget the gearbox will take a little longer to run-in.
I use Motul 7100 4T fully synthetic oil in my 17 year old baby blade and it is just so smooth. I love it.
#16 ·
08silvercbr - When you shut your bike off, does it shut down immediately and I mean immediately. Almost like the bike has tolerences that are a bit tight. The upside for me is I have not added more than a small cup of oil in 3300 miles. Unlike some who have to add a quart every thousand miles. I plan on going semi-synthetic at about 5000 miles. If I am right I should have an engine that has great compression and does not burn oil.
#19 ·
My -08 CBR sounds like old separator. In old days separator was in all country homes. That was used to separate water and some other part's from the milk. I am used allways Motul 7100 10W-40 full synthetic oil. My blade keep also klicking noise somewhere around 3000rpm :eek: . I think that some valve tolerance is over the limit. Must check that in long and dark winter season.
Take listen to new BMW M5 when it starts with cold engine. When the hood is open it sounds like diesel and old stale pushrod? engine is put together.
Mine dosn't eat oil at all. It is carefully break in and thre is never used revs over 10k.
#20 ·
DukeRR8- Yeah shuts off normal. Nothing unusual sounding. I have about 800 miles on now, changed oil 2 times and both times no oil used to speak of. I have to say both times the oil seemed unusually dirty though. Hopefully clean oil helped with the break in process. Probably wont change it again until the end of season so hopefully things stay on the up. I'll keep you posted.
Redleader666- when you idle down...sounding like you are in 1st or 2nd....thats just the slipper clutch doing what its job...not to worry. I think its kinda nice...saves on breaks.
