Fork Removal:
1. Front wheel: Remove brake calipers(12mm) and tie them to your front stand to keep them from just hanging with tension on the brake lines. Loosen right pinch bolts(12mm), remove axle nut(22mm), remove left pinch bolts(12mm). Remove the axle and front wheel.
2. Remove nuts holding brake line brackets(10mm) to the front fender. Remove 4 bolts that mount the fender to forks and remove the front fender.
3. Remove one 8mm bolt holding the clutch lever to clip on so you can rotate it for better access to the upper triple clamp bolt and remove (2) 8mm bolts holding the front brake handle to clip on for better access on the right side.
4. Loosen the upper triple clamp bolt on each side. Using a 32mm wrench or socket loosen the fork cap.
5. Loosen the bolt holding each clip-on to the fork. This only leaves the 2 lower bolts holding the fork in place.
6. Using a 12mm socket loosen the 2 bolts on the lower triple clamp. Be ready because the fork will slide out as soon as you loosen the last bolt.
7. Slide the fork down out of the triple clamps and off the bike.
You are now ready to disassemble the fork.
